[Ed...] Posted July 28, 2020 Share Posted July 28, 2020 Hello everyone, Is it possible to go deeper into root like in attached file? At the moment I can`t go deeper than Base diameter. But I need to see where honing stone end his journey. 🙂Anotācija 2020-07-28 114937.jpg Link to comment https://qualityforum.zeiss.com/topic/14908-root-scan/ Share on other sites More sharing options...
[Ma...] Posted August 4, 2020 Share Posted August 4, 2020 It is not possible to trace an involute curve profile below the base diameter because that is the origination point of the involute curve. Also, when using the traditional generative measurement method the CMM will move the stylus along the base tangent in unison with the rotary axis to trace the profile. Because the stylus can only move along the base tangent it is unable to reach below the base diameter. It is possible to measure the root area against a nominal curve with the CMM using but the results cannot be integrated with the Gearpro profile charts. Link to comment https://qualityforum.zeiss.com/topic/14908-root-scan/#findComment-79364 Share on other sites More sharing options...
[Ri...] Posted August 5, 2020 Share Posted August 5, 2020 As Mark stated, this would be something that you would have to do in Calypso with Curve, but it can easily be accomplished. Link to comment https://qualityforum.zeiss.com/topic/14908-root-scan/#findComment-79366 Share on other sites More sharing options...
[Wo...] Posted August 12, 2020 Share Posted August 12, 2020 You say, you can not go under base diameter. In main technology in measuring profle you get extrapol. scanning path pretravel and posttravel The input is in micrometer and maximum is 1000 . In your case you have set the pretravel. Dont forget to set the acceleration for Profile to less the 10% to avoid had collisions because of deflection of the probe head. Link to comment https://qualityforum.zeiss.com/topic/14908-root-scan/#findComment-79368 Share on other sites More sharing options...
