Theoretical CAD
I have a Go/No-Go gage I need to measure. There is no CAD model, so I created the
gage features (4 cylinders and 4 planes) theoretically. The cylinders change from wire
to solid, but the plane won't go solid? I need them to go solid so I can create a curve(s).
You can always create empty curve - recall points ( this will make nominals for curve ) from elemnt strategy ( plane, circle ... ). When all curves created create new one, or use first one and add nominals from other curves. In fact CAD cut is friendlier, but if there is no another way then this steps will work
