Radius at complicated Curve
Within 2 days I will get the CAD model,what would be the evaluation method, I mean it is maximum inscribed circle??
If I Constrain all the axis , I will get a good result?.
I remember someone else told in this forum after constraining he got fake result.. 🙄
I'm guessing that detail has multiple locations around the ID?
That being the case, scan high point density 2d curves on those
surfaces. Then use Maximum Coordinate for each curve.
This will give you the max point in each curve. Then you can recall
those points into circle feature and constrain whatever work-plane
the measurements done in. You might need to create several secondary
alignments to align to each curve, so you can get the X, or Y Max coordinate.
No, they told me to measure radius separately on each cam.As you told I have to measure six secondary alignment for the six cams.
I would scan it with 2d curve, then simply make cuts with T. planes ( each per 3° as drawn ) and that last one that should touch I would take out from CAD model and that would be last point for circle.
