[SH...] Posted August 7, 2020 Share Posted August 7, 2020 I have to measure unstable 45 degree covering two radius as shown in the red colour mark, when I measure it as two cylinder one side I got 31.85 and other side I got 32.05 . Nominal value 32 diameter.but my production people says it is tool controled ,a single tool both radius should be same. My measuring strategy two segment 4 points per each segment. Evaluation is default method I did not change anything. I constrain the lower diameter cylinder radius then I got 31.9 . What is the best measuring strategy to measure this highly unstable cylinder.IMG_20200807_235854.jpg Link to comment https://qualityforum.zeiss.com/topic/14940-unstable-radius/ Share on other sites More sharing options...
[Ma...] Posted August 10, 2020 Share Posted August 10, 2020 I as ex-milling programmer suspect that milling tool is bending because of unequal material. They should add final clean cut. Try measuring it with points 3x3 - or try to measure a circle or set of circles and review it with profile with locked radius. You will find what is happening there. Link to comment https://qualityforum.zeiss.com/topic/14940-unstable-radius/#findComment-79562 Share on other sites More sharing options...
[An...] Posted August 11, 2020 Share Posted August 11, 2020 See attached.Contribution_11_08_2020_1.xlsm Link to comment https://qualityforum.zeiss.com/topic/14940-unstable-radius/#findComment-79564 Share on other sites More sharing options...
