Vast XXT measuring . . . up ?
Is the Vast XXT designed to be able to measure up? I mean with a stylus pointing in the Z+ direction?
I have an extension going to Y+ with a small star (https://www.renishaw.com/shop/Product.a ... -5000-7811) so 2 of the Ø1mm balls point down at 45's, and 2 point up. I have a couple of smaller calibration spheres to use, Ø5mm with Ø2.5mm stem.
Once it starts scanning the sphere during calibration routine, it sometimes slips off the side and faults. When I say sometimes I mean most of the time. Now, if I slow it way down and use the Sensitive setting, and try enough times, I can get it to take, but how much am I pushing my luck here?
Any thoughts or suggestions welcome, as I'm just experimenting now to see what would be possible and so far I'm not too comfortable with it.
https://qualityforum.zeiss.com/topic/14954-vast-xxt-measuring-up/
And to be honest, it's been months since I've dropped working on it, it could have been the downward tips also. But there was definitely terrible problems with getting all 4 calibrated.
As an FYI, my application is basically what is shown in the Renishaw catalog example, but laid down in the Y+ orientation.
Here is the setup. I was thinking about adding another straight out in the Y+ direction.
https://qualityforum.zeiss.com/topic/14954-vast-xxt-measuring-up/#findComment-79692
You could be right about the angle. I eye-balled the physical orientation intending to be 45° (which is always a tough thing), but I could measure the angle optically to see where it actually lands. I entered the theoretic perfect 45° in the plane during the cal routine - but I suppose at that small scale a little bit of off has a big impact. It wouldn't be that difficult to be more precise in this.
You would use Sensitive and slow it down, correct?
https://qualityforum.zeiss.com/topic/14954-vast-xxt-measuring-up/#findComment-79696
