[Da...] Posted August 9, 2020 Share Posted August 9, 2020 Daft question - I have a clearance box around my part, when I move to the clearance it is taking the distance from the edge of the probing system (VAST gold). I see why, but my styli is shorter then the edge of it and I want to speed things up a bit. Anyone know a solution? Link to comment Share on other sites More sharing options...
[SH...] Posted August 9, 2020 Share Posted August 9, 2020 cannot really understand what you are talking about, but you can control your clearance distance and retract distance inside the measurement plan tab menu. Link to comment Share on other sites More sharing options...
[Da...] Posted August 9, 2020 Author Share Posted August 9, 2020 I’ll post a photo shortly Link to comment Share on other sites More sharing options...
[Da...] Posted August 9, 2020 Author Share Posted August 9, 2020 Apologise for the terrible redactions. So basically you can see the edge of the VAST is at 7mm from the clearance cube, I want that to be 7mm from the styli. I feel secondary clearance is the way but not sure Link to comment Share on other sites More sharing options...
[SH...] Posted August 9, 2020 Share Posted August 9, 2020 Are you working with simulation?? Link to comment Share on other sites More sharing options...
[Da...] Posted August 9, 2020 Share Posted August 9, 2020 David, checkout this post/thread -> viewtopic.php?f=13&t=1311&p=8666#p8651 Link to comment Share on other sites More sharing options...
[To...] Posted August 9, 2020 Share Posted August 9, 2020 Sub-clearance planes would work well. Otherwise, on circular features, you can use the +Z clearance plane as long as the clearance distance is adequate to clear the part as you come down. Same for some linear features that have a clearance distance direction away from the part. Other linear features may require a position point before and after the measuring strategy. Link to comment Share on other sites More sharing options...
