[Ma...] Posted August 5, 2020 Share Posted August 5, 2020 Hello All See Picture below, (excuse my bad paint skills). I am struggling to measure coplanar. I have been trying to set this up with profile but i cant seem to figure it out. The Blue highlighted plane is the datum, the red highlighted planes need to be coplanar to it. Essentially ensuring there is a max overhang/underhang of 0.1mm. Any advice on how I should go about measuring this correctly would be greatly appreciated as I seem to be going around in circles. Thank you in advanced. 🙂 Link to comment https://qualityforum.zeiss.com/topic/14990-co-planar-help/ Share on other sites More sharing options...
[Mi...] Posted August 5, 2020 Share Posted August 5, 2020 Scan each plane, create a Minimum Point and Maximum Point on each one, then report perpendicular distance of each point to the datum. Link to comment https://qualityforum.zeiss.com/topic/14990-co-planar-help/#findComment-80040 Share on other sites More sharing options...
[Jo...] Posted August 5, 2020 Share Posted August 5, 2020 Profile of red area back to Datum. Use bilateral tolerance, equally disposed . If you select two results you will get min, max, and know which side of Datum it is (overhang or below) Link to comment https://qualityforum.zeiss.com/topic/14990-co-planar-help/#findComment-80042 Share on other sites More sharing options...
