[Ji...] Posted July 30, 2020 Share Posted July 30, 2020 Can someone explain to me what you constrain when you click on constrain cone? We are checking 1.500 T.P.F. and had a part checking 1.508, clicked on constrain cone it became 1.503. To make sure we were doing the right thing we checked one that was 1.500 then clicked constrain cone and it made it 1.504. If we had an ideal of what was being constrained we could make a decision whether we should use constrain a cone or not. Right now I am of the opinion that we should not be using it. I am open minded to it if someone can show me why you should use it for T.P.F. Link to comment https://qualityforum.zeiss.com/topic/15030-constrain-on-a-cone/ Share on other sites More sharing options...
[SH...] Posted July 30, 2020 Share Posted July 30, 2020 Your true position datum reference frame will constrain all the degrees of freedom, I don't use that option and to be honest I don't know what is the purpose. I think it is useful for best fit alignment. Link to comment https://qualityforum.zeiss.com/topic/15030-constrain-on-a-cone/#findComment-80380 Share on other sites More sharing options...
[Ri...] Posted July 30, 2020 Share Posted July 30, 2020 Please sign in to view this quote. Constraints should be used when working with either small unstable features, or incomplete features. The most common use of constraints is measuring a short arc radius. You constrain the location to evaluate the radius, and you constrain the radius to evaluate the location. On cones, I have constrained them when they were really small, typically the only thing I would constrain would be the vector. I don't know which constraints you were applying, but if you applied a cone angle constraint when it wasn't needed you will get bogus results. Link to comment https://qualityforum.zeiss.com/topic/15030-constrain-on-a-cone/#findComment-80382 Share on other sites More sharing options...
[Cl...] Posted July 30, 2020 Share Posted July 30, 2020 If you check constraint for "Cone Angle" you will make the angle nominally perfect. By checking "Normal Vector" you will see the AI & A2 values change to zero, I don't believe Calypso will allow you to constraint X,Y, or Z for a cone? Checking constraint for "Radius" should give you a better location. Link to comment https://qualityforum.zeiss.com/topic/15030-constrain-on-a-cone/#findComment-80384 Share on other sites More sharing options...
[No...] Posted July 30, 2020 Share Posted July 30, 2020 No matter what you constrain, it always means that you set the constrained parameter to nominal, so it's no longer part of any (best-) fitting calculation. So basically all you have to consider is: do I want this parameter fixed to nominal or not? Link to comment https://qualityforum.zeiss.com/topic/15030-constrain-on-a-cone/#findComment-80386 Share on other sites More sharing options...
[Ji...] Posted July 30, 2020 Author Share Posted July 30, 2020 Thank you for all of the answers. It confirms what we were thinking. Link to comment https://qualityforum.zeiss.com/topic/15030-constrain-on-a-cone/#findComment-80388 Share on other sites More sharing options...
[Cl...] Posted July 30, 2020 Share Posted July 30, 2020 Please sign in to view this quote. Sorry Richard, I must have been typing at the same time you were. Link to comment https://qualityforum.zeiss.com/topic/15030-constrain-on-a-cone/#findComment-80390 Share on other sites More sharing options...
