[Ad...] Posted July 18, 2020 Share Posted July 18, 2020 Hey guys, I am trying to interpret what the blue print is saying. It is saying that the surface is supposed to be tangent within .005 to the 3.030-3.040 Diameter. How do I go about measuring to get a result? But what I am thinking is the diameter and surface is supposed to be some kind of clearance making sure the diameter and surface are not overlapping. But I would like to know what you guys think. ThanksTangent 2.pngTangent 1.png Link to comment Share on other sites More sharing options...
[SH...] Posted July 19, 2020 Share Posted July 19, 2020 Tangent is s straight line or plane that touches a curve or curved surface at a point.I can't visualise your drawing. Link to comment Share on other sites More sharing options...
[Mi...] Posted July 20, 2020 Share Posted July 20, 2020 Could you do a perpendicular construction from the diameter (measured as a circle) to the plane, then subtract the diameter from the perpendicular's length with a Result Element? Then put the tolerance as 0±.005 Unless I'm picturing it wrong. Link to comment Share on other sites More sharing options...
[Ad...] Posted July 20, 2020 Author Share Posted July 20, 2020 That is what I am thinking. Using a result element to get some kind of result. Seems simple, but I know for sure it is just to make sure the plane and diameter does not overlap within each other + or - .005. Which attributes would I use to subtract from the diameter to the Perpendicular Construction? Would it be the X- Value? Link to comment Share on other sites More sharing options...
[Da...] Posted July 20, 2020 Share Posted July 20, 2020 I am new to programming CMM, however your question got me looking. In the construction drop down menu is an option for Tangents, which gives you 2 features, I would think would be your circle and your line. It puts this in features. I have not used this so I don't really know if it will help you. Link to comment Share on other sites More sharing options...
[Mi...] Posted July 20, 2020 Share Posted July 20, 2020 Please sign in to view this quote. getactual("Circle1").radius - getactual("Perpendicular1").len or something like that Link to comment Share on other sites More sharing options...
