Old Print/True Postition
The attached may help some.
These old prints are always fun. Some customers will work with you, as Keith suggested. Others will just say, "some other shop has been making parts to this print without any trouble for 60 years. Why can't you figure it out?" At least that's been my experience.
The datums were "implied" (I think designers often dimensioned to some common feature and assumed you'd know what they meant but never really thought about "datums" like we do today). In your case, if you're on your own without customer engineering support, I'd use the plane as primary, the 3.10 OD as secondary (most of the dimensions originate at the centerline of this OD), and one of the edges as tertiary.
Also, MMC probably applies to everything by default.
Out of curiosity, is there a drawing standard listed anywhere in the notes? Does anything in the title block indicate what year this was drawn in?
GDT Differences.pdf
Also, simultaneous requirements probably apply. The idea was, in a world without CNC, CMM, computers, or even pocket calculators, where math all had to be done on paper, to allow the machine shop a quick and efficient way to inspect the position of holes. There would have been a flat plate with a pocket that the outside profile fit in to and a bunch of MMC pins to check all the holes in that face at once.
