Autorun - Looping?
Hello all,
We have (4) parts, each with their own inspection, that we want to repetitively measure over a long duration.
We set-up Autorun to measure each inspection in the sequence we desire. The challenging part is how to get it to do 20 or 30 or ?? repeats. Right now our proposed solution is to create an inspection for each repetition. 4 inspections x 20 repeats = 80 inspections....gets out of hand really quickly.
Anyone know of a way to 'loop' Autorun? Is there another way to accomplish the task?
Thanks in advance!
Brian
https://qualityforum.zeiss.com/topic/15170-autorun-looping/
Thank you for the responses.
I have limited experience with Autorun and Pallet so forgive the simple questions.
1. Can anyone offer good resources for working with the Pallet program? I assume the Zeiss help menu is limited in its usefulness.
2. Will Pallet loop sequentially (i.e. 1, 2, 3, 4, 1, 2, 3, 4) or will it loop each inspection to completion and then move on (i.e. 1, 1, 2, 2, 3, 3, 4, 4). Or maybe it can do both depending on how it is set-up.
Thanks again.
Brian
https://qualityforum.zeiss.com/topic/15170-autorun-looping/#findComment-81548
