clearance data vs. cmm positioning
Pros - Faster, cleaner, exact
Cons - Takes much more time to set up
I typically use cmm positions when I have to do like a -Y,+Z,+Y clearance moves in one feature back to back to back. Not only is it faster, but sometimes the CMM will do some wonky moves that doesn't make sense when stacking clearance moves (at least in my experience). I also suggest CMM positions if you're changing an RDS angle in between measuring strategies for a single feature. It's also helpful when measuring the counter-bore diameter, depth, and hole diameter. Just a lot cleaner/faster.
Also, if you didn't know, you can change the exact x,y,z of the cmm position in the strategy window as well. Helpful when you want to position right in the center of a hole.
On your note about measuring the counterbore diameter, depth, and hole diameter, have you ever used sub-clearance planes? It's great for this purpose.
Position points are great if you don't ever plan on changing the program. Clearance Planes are easier as the program shrinks, and grows.
Thanks all.
I'll stick with the position points for now.
I don't get into too many complicated positioning issues.
If I have to add a lot of position points I'll do my trick of inverting the clearance distance value with the retract distance and just jump around.
I use them for "eyeball" alignments, extremely useful. Like say you have a hole of a bolt pattern that is on center that you may use to align for the Base Alignment. I create a position point above the part slightly and "X" or "Y" location, I put in a programmable stop referring to align the hole to the probe and then we're cooking with gasoline.
Your part would need to be able to rotate about Z in the fixture before you clamp it down with this method though.
I agree with you, (sub)clearance planes are for sure more future proof.
Sub clearance planes are something I need to read more on. The way I do them, it normally takes longer than just creating cmm position points. There's probably a better way, and I just don't know it yet.
Over the years i've started trusting Calypso to move around by itself.
Clearance moves and Block edges is usually all i need to safely get around fixtures and 'up & over' my workpiece.
Don't get me wrong, some of my older programs have very detailed XY&Z moves.
Now usually the most ill do to be safe is to combine clearance moves to get the head moving in a safe direction, like going +X then +Z before the next feature which is going to be -X clearance.
But i have an XT so i don't have to deal with articulation.
Additionally the programs i work with in our Detroit facility use XXT, and those programs always jet up in +Z before the head spins, for those programs that keeps everything safe.
Additionally2, if you have cad models of your fixtures, that helps tremendously in programming.
