GD&T, ASME, tolerancing a pattern to a pattern
I'm looking for either the section in ASME that covers this question and/or your thoughts on the best way to tolerance this...
Let's say I have a pattern of holes that are a datum feature. Each of those holes in turn has a slot centered to each hole individually in the pattern. Although the slots are a pattern, so to speak, each slot feature needs to be independently located to the hole it surrounds. What is the correct method to tolerance this?
I've seen callouts that tolerance the slots and reference the datum pattern with a note like.... 8 plcs, individually or something similar, but I'm unsure if there is a specific way to tolerance this or if it's interpretive.
Thanks all for any feedback you can provide,
Robert
Andreas, you should really start stating you're concerns/questions as opposed to just throwing question marks on things. I know you have a great understanding of GD&T, so I have no clue what doesn't make sense to you.
It would also help not-so-familiar forum members (including myself) follow along better.
Here's my interpretation of what's going on in 7-37 of 2009:
The lower "segment"which is not really a segment, because it's a separate Feature Control Frame and not a PLTZF controlis intended to ensure that each mating component will fit without interference into the larger hole and the four surrounding holes. It's a clearance requirement. Hence the MMC applied to the tolerance and the MMB applied to the datum D reference. They put down 6x for the lower FCF because that's the control that ties each pattern of surrounding holes to its corresponding central datum hole.
I haven't the foggiest notion of a functional requirement that might be addressed by the upper FCF.
Your "Pic. #1":
I have no idea where this example came from, because you didn't give your customary reference. However, this is a completely different situation, because in this case the "6x" refers to a pattern of six features instead of six patterns of features and is intended to means 6x for both the upper and lower FCF. Again, this is not a composite FCF but two different FCFs because they each have their own position symbol. The diameter symbol preceding the tolerance amount indicates the shape of the tolerance zone for each feature as it always does in ASME (as well as ISO).
