[An...] Posted July 8, 2020 Share Posted July 8, 2020 Regarding TP Ø0.8 (M) ABC (6x) See attached.Pic_7-46_b.pdf Link to comment https://qualityforum.zeiss.com/topic/15240-true-position-2x-and-pattern/ Share on other sites More sharing options...
[Da...] Posted July 8, 2020 Share Posted July 8, 2020 6x means that this applies to 6 same holes which applies the same rule. TP is coordinate and is a refference to plane A and B in C base planes. Link to comment https://qualityforum.zeiss.com/topic/15240-true-position-2x-and-pattern/#findComment-82016 Share on other sites More sharing options...
[Da...] Posted July 8, 2020 Share Posted July 8, 2020 Andreas, to what standard are you asking? If ISO, all 6 are to be evaluated separately, if ASME, ALL of the holes in this case (6x and 4x and 3x) simultaneously. Link to comment https://qualityforum.zeiss.com/topic/15240-true-position-2x-and-pattern/#findComment-82018 Share on other sites More sharing options...
[An...] Posted July 8, 2020 Author Share Posted July 8, 2020 Please sign in to view this quote. I am not asking for any standard,because for me the standard is not the "bible". Just trying to understand functional phenomenons by the means of technical logic. Using the three-times-pattern and trying to explain the "part #1;part #2;part #3 - principle". See attached.Pic_7-46_c.pdf Link to comment https://qualityforum.zeiss.com/topic/15240-true-position-2x-and-pattern/#findComment-82020 Share on other sites More sharing options...
[Aa...] Posted July 13, 2020 Share Posted July 13, 2020 That's from Y14.5-2009. It's explained on the following page. Link to comment https://qualityforum.zeiss.com/topic/15240-true-position-2x-and-pattern/#findComment-82022 Share on other sites More sharing options...
