True Position (2x) and pattern
6x means that this applies to 6 same holes which applies the same rule.
TP is coordinate and is a refference to plane A and B in C base planes.
Andreas, to what standard are you asking?
If ISO, all 6 are to be evaluated separately, if ASME, ALL of the holes in this case (6x and 4x and 3x) simultaneously.
I am not asking for any standard,because for me the standard is not the "bible".
Just trying to understand functional phenomenons by the means of technical logic.
Using the three-times-pattern and trying to explain the "part #1;part #2;part #3 - principle".
See attached.
Pic_7-46_c.pdf
