[Ke...] Posted July 6, 2020 Share Posted July 6, 2020 Starting not to to like Duramax's. I'm trying to qualify probes but there is 2 masters. 1 Long, 1 Short which do I use?? Also no matter which Master I use to qualify the master sphere. I try set the probe length off the top of the Table. Then I set the probe rack position. Only to have XXT Head come in about an inch to high (picture attached) Any help is appreciated Dearly. Thanks in advance..20200706_180606.jpg Link to comment Share on other sites More sharing options...
[An...] Posted July 7, 2020 Share Posted July 7, 2020 The red probe is the right one! As far as I know, the blue probe is used to calibrate the rotary table. The red probe is also used to calibrate the rack. Link to comment Share on other sites More sharing options...
[Ke...] Posted July 7, 2020 Author Share Posted July 7, 2020 Both probes are RED based Master Probes. Also according to Zeiss's Store you can order masters for the Duramax in a Long or Short Format. Link to comment Share on other sites More sharing options...
