[Ke...] Posted July 1, 2020 Share Posted July 1, 2020 We recently purchase a used Duramax, when I start calypso 5.6 the Auto Run screen is the only thing that comes up. I CANNOT get the regular Calypso interface screen to come up. I am logging as Master if that helps. This all started when the probes and probe rack all disappeared and need to recreate the missing probe and set the probe rack position. thanks Link to comment https://qualityforum.zeiss.com/topic/15334-duramax-startup/ Share on other sites More sharing options...
[Öz...] Posted July 1, 2020 Share Posted July 1, 2020 Check this menu. Hope it will solve the problem. Link to comment https://qualityforum.zeiss.com/topic/15334-duramax-startup/#findComment-82520 Share on other sites More sharing options...
[Ke...] Posted July 1, 2020 Author Share Posted July 1, 2020 Can you access this settings pop-up window Through the Auto Run window? Link to comment https://qualityforum.zeiss.com/topic/15334-duramax-startup/#findComment-82522 Share on other sites More sharing options...
[Ia...] Posted July 1, 2020 Share Posted July 1, 2020 If you're in the auto run interface, you can go to file -> end/start calypso, and it will open up the main calypso screen. Link to comment https://qualityforum.zeiss.com/topic/15334-duramax-startup/#findComment-82524 Share on other sites More sharing options...
