[Ti...] Posted June 18, 2020 Share Posted June 18, 2020 I am constantly changing the speed and step width settings on polylines for the small parts I measure. The default is Speed=15, and Step Width=3. I almost always change them to 5, and 1 (or less). Is there a way to change the defaults to 5 and 1? I'm using Calypso 2015 Service Pack 2. Link to comment https://qualityforum.zeiss.com/topic/15428-default-speed-and-step-width-settings/ Share on other sites More sharing options...
[SH...] Posted June 18, 2020 Share Posted June 18, 2020 - Link to comment https://qualityforum.zeiss.com/topic/15428-default-speed-and-step-width-settings/#findComment-83346 Share on other sites More sharing options...
[Ke...] Posted June 18, 2020 Share Posted June 18, 2020 Extras---Settings---Measurement--Point Density Extras---Settings---Navigator (2nd tab from bottom) and you can set to Tolerance Dependant, for scan speed Link to comment https://qualityforum.zeiss.com/topic/15428-default-speed-and-step-width-settings/#findComment-83348 Share on other sites More sharing options...
[To...] Posted June 19, 2020 Share Posted June 19, 2020 Please sign in to view this quote. Under Resources > Save/Load Defaults. Click the Strategy tab. Activate the features that you want to set the default values for. Click the "wrench" icon to edit the strategy. Add a strategy from the top, like you would if you were in the feature. Double-click the strategy to edit it. Modify the parameters to your liking. Click OK to close the window. Repeat for other features. Click the SAVE button and give this strategy a name. Create additional strategy profiles, as needed for various applications. Whichever profile is active when you close this window will stay active indefinitely.polylines.pdfDefault Measurement Strategy.pdf Link to comment https://qualityforum.zeiss.com/topic/15428-default-speed-and-step-width-settings/#findComment-83350 Share on other sites More sharing options...
[Ti...] Posted June 22, 2020 Author Share Posted June 22, 2020 @Tom Oakes: Thank you, that looks like what I've been wanting to change. A follow up question is: How do I add other features to the default list that comes up on the Strategy tab? I would also like to change defaults for 3d Curves....they always run too fast especially with a 1mm stylus. Link to comment https://qualityforum.zeiss.com/topic/15428-default-speed-and-step-width-settings/#findComment-83352 Share on other sites More sharing options...
[Ro...] Posted June 22, 2020 Share Posted June 22, 2020 Will this work for ff surfaces Tom? My machine currently defaults to 2mm step width, i always have to edit my speed and step width to .005 inch.jhkjhvghxfgc.JPG Link to comment https://qualityforum.zeiss.com/topic/15428-default-speed-and-step-width-settings/#findComment-83354 Share on other sites More sharing options...
[To...] Posted June 22, 2020 Share Posted June 22, 2020 Please sign in to view this quote. Nope.... Link to comment https://qualityforum.zeiss.com/topic/15428-default-speed-and-step-width-settings/#findComment-83356 Share on other sites More sharing options...
[To...] Posted June 22, 2020 Share Posted June 22, 2020 Please sign in to view this quote. On that screen, what you see is what you get. Link to comment https://qualityforum.zeiss.com/topic/15428-default-speed-and-step-width-settings/#findComment-83358 Share on other sites More sharing options...
[To...] Posted June 22, 2020 Share Posted June 22, 2020 How about using Features Setting Editor to edit speeds, step widths, # of points, etc.? . Link to comment https://qualityforum.zeiss.com/topic/15428-default-speed-and-step-width-settings/#findComment-83360 Share on other sites More sharing options...
