CAD Model not loading
Hey guys,
When I try to upload a CAD model to Calypso I keep getting error when trying to the load the model. The model is a .step file. I never had issues before but now I keep getting an error. See the attached for the error call out. The CAD models are downloaded from a system we use from the company and they are uploaded to JAVA and I would have to save the model from JAVA to a file on a desktop. I never I had an issue before but I cannot get the CAD models to load into Calypso.
Thanks.
https://qualityforum.zeiss.com/topic/15494-cad-model-not-loading/
Its the CAD kernel or simulation losing it's connection.
I get this from time to time when I switch on/off from the company VPN. (All open sockets are restarted so some of them can be encrypted) So the only advice I can give is to talk to your IT guys and ask if something funky goes on when you use "JAVA".
I usually solve it by pressing ok, and redo what ever I did.
https://qualityforum.zeiss.com/topic/15494-cad-model-not-loading/#findComment-83868
  • 2 weeks later...
This is where I get the CAD models from, and the process to save them in the desktop as .stp or .step file. I did this before, and Calyspo would be able to upload them. But now it will give me the error as shown in the first post. Is a conversion problem, or should I talk with IT and engineering about the situation?
Thanks.
See attached.
https://qualityforum.zeiss.com/topic/15494-cad-model-not-loading/#findComment-83874
The only other thing I can think of other that what has been suggested is to check the version of STEP/SAT file it's exporting. Newer/different versions of .stp & .sat are not compatible with older/different versions of Calypso. If you've changed no settings and it doesn't work the way it did then I would suspect you have a corruption/communication problem.
https://qualityforum.zeiss.com/topic/15494-cad-model-not-loading/#findComment-83882
Well, if that used to be a STEP file I can verify that Calypso 2018 REALLY doesn't like it.
I can't pretend to know STEP's structure, but it looks substantially different from my own files. Looping back to what Robert said earlier in the thread, when you used that Convert option in AutoVue, did you convert it to an STL? The settings in the first screenshot you posted of that program suggest that.
https://qualityforum.zeiss.com/topic/15494-cad-model-not-loading/#findComment-83892
I change it to .stp when I save it but calypso is not able to open it and would give me that error when I first posted. But before it would work. But I am not sure the cause but when I updated Java AutoVue would not open but when the IT guy looked at it, he told me the engineers do not used the current version of JAVA. So the IT went back and uploaded the previous version of JAVA. But AutoVue would open but now the .stp files would not open from Calypso. Do you think Calypso was trying to open a .stp file that is coming from an old version? or it does not matter?
https://qualityforum.zeiss.com/topic/15494-cad-model-not-loading/#findComment-83894
OK, I just verified your file is an STL file, which explains why Calypso throws a fit. I managed to get it to open in Paint 3D and IronCAD with the .stl extension, and not at all with the .stp extension.
I'd like to cover a basic check here: how are you saving it out of AutoVue for use in Calypso? If it worked before your Java adventure, I assume you're converting it back to STEP and not just changing the file extension? If so, then your program isn't actually doing any conversion right now.
https://qualityforum.zeiss.com/topic/15494-cad-model-not-loading/#findComment-83896
