No Start Value for Iteration....
  • 8 months later...
It is part specific also.
I can execute just the cylinder on a different part with no problem and then remeasure the cylinder on the first part and get the message again.
Filter and outlier elimination turned on or off appear to have no effect on this as well.
The only thing I have seen get rid of the message is changing the evaluation range. The problem is I would need to adjust it to the point where there is not much measurement left to accurately evaluate. Then the message will go away.
My understanding is that this error has something to do with the algorithm that is used to best-fit cylinders (and maybe other geometry, too). I usually run into it checking large diameter, short length cylinders like you mentioned.
I don't know of a fix, but depending on what you need to measure, you might be able to measure several 2d circles at different heights and recall them into a 3d line instead.
I created more space between the 2 cylinder circle paths and the issue went away.
Working with a part around Ø200 mm and 9mm thick.
One circle path at -2mm from the top and the other at -7mm.
I dropped the height of the bottom path by 1mm.
In case anyone else was interested.
