True Position
Datum reference A(M) is a cylinder at MMC 16.0. Datum feature A is free to translate/rotate throughout this boundary. The issue here is that in the real world, and if the part was held as drawn, gravity would interact and force datum feature B to fall flat on the faces of the datum feature simulator (actually, it would fall flat on the faces of the simulator for datum B, which would be normal to the simulator of A). It is probably not the best image to explain a primary datum referenced at MMB, but the theory is understandable.
https://qualityforum.zeiss.com/topic/15550-true-position/#findComment-84278
The moveable segments of the datum simulator A,driven by the spring forces,
ensure the mobility of the complete system,if necessary.
Target: keep the datum A-cylinder always untilted and simultaneously
profit by the difference of maximum-material and actual-material.
https://qualityforum.zeiss.com/topic/15550-true-position/#findComment-84286
The cylinder as primary datum A stopps 4 degrees of freedom:
1.) X - coordinate (translation)
2.) Y - coordinate (translation)
3.) a1 - angle (rotation)
4.) a2 - angle (rotation)
Stopping the rotation means:
Tilting is not allowed.
Translation is allowed within in the MM-boundary.
(my personal point of view)
Evaluation in this case is:
MINIMUM CIRCUMSCRIBED CYLINDER
See attached
Pic_4-21b.pdf
https://qualityforum.zeiss.com/topic/15550-true-position/#findComment-84292
The datum is not a cylinder, it's an axis. The datum feature simulator is a cylinder, and the datum feature is an imperfect cylinder. The datum axis for a cylindrical datum feature must be selected from among the "candidate datums", and should be selected to give the optimal results for the impacted feature control frames.
https://qualityforum.zeiss.com/topic/15550-true-position/#findComment-84300
Making a statement that contradicts what's contained in the standards and labeling it "technical logic" doesn't change the fact that it contradicts the standards. The fact that you don't think the standards should be written the way they are doesn't change the fact that they are written that way.
"The datum mobility works always translatory !" I don't know where you are getting this.
https://qualityforum.zeiss.com/topic/15550-true-position/#findComment-84304
No, that would not be ambiguous. The secondary planar datum would be required to be perpendicular to datum A, just as you have drawn it. But it would not be required to contact a minimum of three points on the surface of the corresponding datum feature.
https://qualityforum.zeiss.com/topic/15550-true-position/#findComment-84310
