Software 2022 Service Pack 1
Hi,
      After using Zeiss Quality Suite to update Inspect Pro to 2022 Service Pack 1, I am no longer able to open the Zeiss Quality Suite.
Is this a full re-install required to remedy?
Yes, a full installation fixed it.
Perhaps I should have installed the update to Zeiss Quality Suite prior to GOM Software.....
Normally a full re-install should not be necessary. In our tests, updating from Inspect Pro to 2022 SP 1 via the suite always worked without any problems.
We would like to investigate the problem in more detail to find out the cause. Therefore, it would be a great help if you could open a ticket for this problem via support.optical.metrology@zeiss.com with a detailed description about the behavior.
