Line Profile vs Surface profile
I have an ID contour that has a .002 surface profile callout to -A- & -B-. So, I did what I normally do, I created two 2d curves 180 deg apart. Recalled the points into a Free Form Surface, and the result is .043. Impossible, all the diameters, angles, and depths are correct. So I took the two 2d curves and put them in two line profile characteristics. They both measure about .001. Why am I getting such huge differences in the two when they a both using the same points?
https://qualityforum.zeiss.com/topic/15560-line-profile-vs-surface-profile/
I believe it shows up incorrect due it being a 2D datum structure, depending on how you measured cylinders/circles or lines/planes for your datum features. If you use just those two datums as lines or circles in a surface profile, Calypso may calculate them incorrectly. If you make an alternate alignment using just those two datums or measure them as 3D features, it should come out using the FF Surface.
That's just my experience. Some other well spoken individual may have a different answer.
Ah yes, I see that. I've never had to us it. Don't think it would
help in this instance, as there are obstructions before and after
the scanned area that the ruby would hit.
On another note, I got an error message after scanning, telling
me something about no gauss circle filter setting for this available.
So I looked in the evaluation and saw that the filter setting was Gauss.
I changed it to Spline, then got another message suggesting that I
divide the curve length x2 for the filter wavelength?
