Hole Distance Help
I have to measure a distance from an outer wall of a hole to the plane highlighted. What is the best way to measure this feature? I'm unsure of how to build the characteristic and obtain this value.
Thanks,
I did not get 100 percentage idea about your geometry even though, I would prefer caliper distance.
There's a plane that I have to measure the distance from. I need the outermost point of the hole as my distance back to the plane.I have never done this and only done center line back to the plane. My CMM programmer is also not sure how to do this.
An alternate method would be to use a maximum or minimum point feature. Scanning the diameter as a curve and getting the point from that works well.
There will be a shaft that is placed in the hole. This shaft will then have a key inserted into it and it needs to pass a slip test. So that size will be used for a function check. This is essentially a pass/fail fixture. No standards on print. ISO would be the direction if so.
Scanning will be difficult as there is a slot feature through this diameter.
Destructive testing send a Video. Not sure then what dim you really need. Sounds more like the point on the top surface.
