[wi...] Posted June 4, 2020 Share Posted June 4, 2020 I have to measure a distance from an outer wall of a hole to the plane highlighted. What is the best way to measure this feature? I'm unsure of how to build the characteristic and obtain this value. Thanks, Link to comment Share on other sites More sharing options...
[SH...] Posted June 4, 2020 Share Posted June 4, 2020 Please sign in to view this quote. I did not get 100 percentage idea about your geometry even though, I would prefer caliper distance. Link to comment Share on other sites More sharing options...
[wi...] Posted June 4, 2020 Author Share Posted June 4, 2020 Please sign in to view this quote. There's a plane that I have to measure the distance from. I need the outermost point of the hole as my distance back to the plane.I have never done this and only done center line back to the plane. My CMM programmer is also not sure how to do this. Link to comment Share on other sites More sharing options...
[Za...] Posted June 4, 2020 Share Posted June 4, 2020 select maximum in the drop down for caliper distancecaliper distance-.png Link to comment Share on other sites More sharing options...
[Da...] Posted June 4, 2020 Share Posted June 4, 2020 That depends on what you are trying to do what are they asking for? Is it to ASME or ISO?Capture.JPG Link to comment Share on other sites More sharing options...
[Me...] Posted June 4, 2020 Share Posted June 4, 2020 An alternate method would be to use a maximum or minimum point feature. Scanning the diameter as a curve and getting the point from that works well. Link to comment Share on other sites More sharing options...
[wi...] Posted June 4, 2020 Author Share Posted June 4, 2020 Please sign in to view this quote. There will be a shaft that is placed in the hole. This shaft will then have a key inserted into it and it needs to pass a slip test. So that size will be used for a function check. This is essentially a pass/fail fixture. No standards on print. ISO would be the direction if so. Link to comment Share on other sites More sharing options...
[Da...] Posted June 4, 2020 Share Posted June 4, 2020 Please sign in to view this quote. I think that is a great idea. Link to comment Share on other sites More sharing options...
[wi...] Posted June 4, 2020 Author Share Posted June 4, 2020 Please sign in to view this quote. Scanning will be difficult as there is a slot feature through this diameter. Link to comment Share on other sites More sharing options...
[Da...] Posted June 4, 2020 Share Posted June 4, 2020 Please sign in to view this quote. Destructive testing send a Video. Not sure then what dim you really need. Sounds more like the point on the top surface. Link to comment Share on other sites More sharing options...
[wi...] Posted June 4, 2020 Author Share Posted June 4, 2020 Got an accurate results. Thanks for the help everyone! Link to comment Share on other sites More sharing options...
[Da...] Posted June 4, 2020 Share Posted June 4, 2020 How you change the Side of a Caliper measurement Attached is how you make the Caliper measurement on the top and bottom The changes made to change the point it measuresCapture2.JPGCapture1.JPGCapture.JPG Link to comment Share on other sites More sharing options...
