[ch...] Posted December 20, 2019 Share Posted December 20, 2019 What is the use of merged measurement plan?? How can I create it??2019-12-20 21.53.04.jpg Link to comment https://qualityforum.zeiss.com/topic/15636-merged-measurement-plan/ Share on other sites More sharing options...
[Ri...] Posted December 22, 2019 Share Posted December 22, 2019 It's for use on horizontal arm CMMs - where you'd have an arm on one side of the artifact, and one on the other. It allows you to bring all the data into one program/report. Link to comment https://qualityforum.zeiss.com/topic/15636-merged-measurement-plan/#findComment-84960 Share on other sites More sharing options...
[Ke...] Posted December 26, 2019 Share Posted December 26, 2019 Please sign in to view this quote. So... could this be used on a bridge cmm, where two separate programs are required to inspect 100% of the part? Link to comment https://qualityforum.zeiss.com/topic/15636-merged-measurement-plan/#findComment-84962 Share on other sites More sharing options...
[Er...] Posted December 26, 2019 Share Posted December 26, 2019 Yes, you can use how ever you wish. I've sometimes used it to take two measurements plans from different "tempos" to merge in to one protocol. Doesnt really matter if its an arm, bridge or a micura. As long as you have two plans with results, you can use it. Its like a subsequent evaluation for two plans, that fu*ks up your naming in the protocol. Link to comment https://qualityforum.zeiss.com/topic/15636-merged-measurement-plan/#findComment-84964 Share on other sites More sharing options...
[Cl...] Posted June 2, 2020 Share Posted June 2, 2020 Ok, I go to File - Create merged measurement plan. Now what? Link to comment https://qualityforum.zeiss.com/topic/15636-merged-measurement-plan/#findComment-84966 Share on other sites More sharing options...
[Öz...] Posted June 2, 2020 Share Posted June 2, 2020 When you open a merged plan then you will have a new selection in resourcess menu called "import measurement plan". then from here you will import 2 measurement plans and you this merged plan for just calculation. it is usefull when you cant measure the part with just one time on the CMM. so you first measure the part ( for example upper side) then flip the part and measure again. then merge them in one part. or your Y axis is 1000 mm and your part is 1500 mm . then you measure 2 times the part and merge in one plan. magically your y axis is now 1500 mm 🤣 Link to comment https://qualityforum.zeiss.com/topic/15636-merged-measurement-plan/#findComment-84968 Share on other sites More sharing options...
