[Ke...] Posted May 27, 2020 Share Posted May 27, 2020 So I went to do a probe change. The head moved back fine but will not rotate to put the probe away and is just not moving at all. No errors or warnings. I had stopped the program using the esc button just before a rotation change just prior but everything was fine when I went to put this probe away. I may have to reboot 🙁 Link to comment https://qualityforum.zeiss.com/topic/15642-probe-change-not-rotating/ Share on other sites More sharing options...
[Ke...] Posted May 27, 2020 Author Share Posted May 27, 2020 So I went into the Probing System Qualification menu and I got the below message I also got the pop up menu to rotate to the position the probe was in but still it doesn't move. Link to comment https://qualityforum.zeiss.com/topic/15642-probe-change-not-rotating/#findComment-85000 Share on other sites More sharing options...
[Mi...] Posted May 28, 2020 Share Posted May 28, 2020 when you hit the esc while it's doing a probe change ( or when it's even thinking about doing one) it will forget what probe is in the holder. Look in the stylus selected window on the tool bar. If it says unknown, do a manual change but only do the pick up stylus and enter the probe you are using. Link to comment https://qualityforum.zeiss.com/topic/15642-probe-change-not-rotating/#findComment-85002 Share on other sites More sharing options...
[Ke...] Posted May 28, 2020 Author Share Posted May 28, 2020 Please sign in to view this quote. I have had that happen before. In this case the probe window was still reading the probe that I was using. I do think that is what happened but it really confused the software in this case took a little extra effort. Link to comment https://qualityforum.zeiss.com/topic/15642-probe-change-not-rotating/#findComment-85004 Share on other sites More sharing options...
[Da...] Posted June 2, 2020 Share Posted June 2, 2020 This was working at one point or a new probe holder location? Link to comment https://qualityforum.zeiss.com/topic/15642-probe-change-not-rotating/#findComment-85006 Share on other sites More sharing options...
