[Ve...] Posted May 26, 2020 Share Posted May 26, 2020 Hello, we don't have the PCM option on the machine or the offline seat. There are no "loops" set on any of the characteristics. The define macros screen is blank. Every time we run a program, it measures the features 6 times each. How do we get it to measure them one time each? Thanks Link to comment Share on other sites More sharing options...
[Da...] Posted May 26, 2020 Share Posted May 26, 2020 Does it run the complete program, then starts over from the beginning, OR does it run the first feature 6 times before advancing to the next feature? Link to comment Share on other sites More sharing options...
[Ve...] Posted May 26, 2020 Author Share Posted May 26, 2020 It runs through all the features, then repeats all of them. The features turn green as they are probed. once all of them have been run six times each, all of the characteristics turn green. Link to comment Share on other sites More sharing options...
[Er...] Posted May 26, 2020 Share Posted May 26, 2020 Either your Characteristic tree is looped, shown as (1,6,1) under the tabs for CMM, Meas.. Plan, Char.. If so right click > loop > delete. Or you have "repeat measurement" on. Plan > Repeat measurement.. Link to comment Share on other sites More sharing options...
[Ve...] Posted May 26, 2020 Author Share Posted May 26, 2020 Thanks for your replies, Here is pic of settings, I can find nothing with loop set. Loop Start - end - step is blank for all the char. With no char highlighted, it is blank. Repeat not checked. Also tried checking repeat and setting max at 1. Link to comment Share on other sites More sharing options...
[Er...] Posted May 26, 2020 Share Posted May 26, 2020 Intresting... but then I have no clue. 😃 Link to comment Share on other sites More sharing options...
[Ve...] Posted May 26, 2020 Author Share Posted May 26, 2020 thank you for trying...i entered a help ticket Link to comment Share on other sites More sharing options...
[Is...] Posted May 27, 2020 Share Posted May 27, 2020 other two possibilities (if the program was not developed by you): - Check the loops in the measurement strategies of the features. - Open the inspection file with the notepad and search for loop or measure PCM functions: i.e. measure(FeatureName[,LoopIndex]) for i=1 to 4 [step 2] ... next i repeat ... until i>10 Link to comment Share on other sites More sharing options...
[SH...] Posted May 27, 2020 Share Posted May 27, 2020 Please sign in to view this quote. Please don't mistake me, after reading your post I feel like reading fairy tale stories.... Did you tried Israel ideas?? Link to comment Share on other sites More sharing options...
[Da...] Posted May 27, 2020 Share Posted May 27, 2020 Just a thought, does your base alignment have a loop ? It wouldn't cause this but.... One more thing, I see you have multiple alignments. Is there a chance you have features called out in an order that Calypso has to recheck an alignment in order to " over ride "a previous alignment ? I'm pretty sure this wouldn't produce the results you are getting, but never hurts to check 😉 Link to comment Share on other sites More sharing options...
[Ve...] Posted May 27, 2020 Author Share Posted May 27, 2020 Hello Israel, i don't see any loops associated with the features. code attached.inspection.txt Link to comment Share on other sites More sharing options...
[Ve...] Posted May 27, 2020 Author Share Posted May 27, 2020 Hello Dave, the extra alignments are derived from the base alignment. if there is a loop on the base alignment, i cant find it. Link to comment Share on other sites More sharing options...
[Ow...] Posted May 27, 2020 Share Posted May 27, 2020 Sometimes it's easy to not see the forest for all the trees in the way. I don't have access to Calypso right now but, Go to plan, repeat measurement. Link to comment Share on other sites More sharing options...
[Ve...] Posted May 27, 2020 Author Share Posted May 27, 2020 Pic is from current setting. Also tried checking the box and setting the Max to 1. that did not work either. Another clue might be "in simulation it does not repeat" on the machine it does. Link to comment Share on other sites More sharing options...
[Ow...] Posted May 27, 2020 Share Posted May 27, 2020 Yeah, I didn't mean to sound sarcastic but, thought it was worth a try. Sometimes a program gets an algorithmic glitch in it and there have been a few times in the last 14 years that I've had to recreate the whole program anew to fix an issue.Sometimes quicker than waiting for support 🙄 Link to comment Share on other sites More sharing options...
[Is...] Posted May 27, 2020 Share Posted May 27, 2020 Please sign in to view this quote. Definitely not in the inspection file, other Chance: What about in the inspset file? Link to comment Share on other sites More sharing options...
[Da...] Posted May 27, 2020 Share Posted May 27, 2020 Any chance you're using autorun? Link to comment Share on other sites More sharing options...
[Ja...] Posted May 27, 2020 Share Posted May 27, 2020 Please sign in to view this quote. It looks like you are not looping your alignment 1, but if you right click and select loop without having any characteristic highlighted, what do you get? I get "loop-cfs" . Link to comment Share on other sites More sharing options...
[Mi...] Posted May 27, 2020 Share Posted May 27, 2020 Hmm...I'm curious what happens if you turn "repeat measurement" on, but set the max to 1. If this fixes it, it would probably be a bug, but it might be worth a shot. Also, was this a program you wrote? Or did you get it from elsewhere? Link to comment Share on other sites More sharing options...
[Ve...] Posted May 28, 2020 Author Share Posted May 28, 2020 thanks for all your ideas. been a good learning experience. i checked the code, all the characteristics, the repeat run for loops. even set the repeat run max to one. the one thing i forgot to check was the base alignment. the loop was there. again, thanks everyone for your help! Link to comment Share on other sites More sharing options...
[Jo...] Posted May 28, 2020 Share Posted May 28, 2020 Hi Verl, why repeats 6 times rather than 10 times 🤣 Link to comment Share on other sites More sharing options...
