[Li...] Posted May 7, 2020 Share Posted May 7, 2020 We are getting ready to update one of our CMM's with latest version of Calypso. In addition we are going to be using a different computer. This CMM run in this cell uses AutoRun for the operators ease of access. The main programs are on a server. The AutoRun I believe populates from this server. Will I need to create all the AutoRuns again or will ."arn " file do it? Is it something that is saved/controlled in the Calypso software? Thanks Lincoln Link to comment Share on other sites More sharing options...
[SH...] Posted May 7, 2020 Share Posted May 7, 2020 Please sign in to view this quote. If you saved the auto run program in the server then no need to create new one, in my knowledge you can't save anything in the Calypso software. First you create a maintenance backup otherwise you will miss all your probe details. Link to comment Share on other sites More sharing options...
[CA...] Posted May 26, 2020 Share Posted May 26, 2020 Hello CMM community I have created an AUTORUN, with Info and Videos, but when I try to add a USER I got an error, here in picture the details. How to avoid such error? I have created the Password and the Privileges!? IP as localhost Link to comment Share on other sites More sharing options...
[Mi...] Posted May 26, 2020 Share Posted May 26, 2020 Are you logged into Calypso as the Master? Have to do that in order to make any of the changes that you speak of Link to comment Share on other sites More sharing options...
[CA...] Posted May 27, 2020 Share Posted May 27, 2020 Thanks Mike, I was logged as master, but I thought that the problem is that I have not made the new user entrance thru Extras-Setting-... I have made it direct in Autorun. I have proved in Planner offline in other PC thru Extras-Setting usw. and was success. I'm trying now with the connected PC-CMM Link to comment Share on other sites More sharing options...
