[Te...] Posted May 7, 2018 Share Posted May 7, 2018 Does any have the correct MasterProbe offset for planner for Calypso 2017 with a Contura 2014 with an RDS XXT. My probe is not touching the part. Link to comment https://qualityforum.zeiss.com/topic/15712-masterprobe-planner-offset-rds-xxt/ Share on other sites More sharing options...
[To...] Posted May 8, 2018 Share Posted May 8, 2018 try this. You'll find several replies with numbers very close on Z Link to comment https://qualityforum.zeiss.com/topic/15712-masterprobe-planner-offset-rds-xxt/#findComment-85580 Share on other sites More sharing options...
[CA...] Posted May 22, 2020 Share Posted May 22, 2020 Hello CMM Form Now I got in my offline Planner the message: Well, anyway we are with problem, only a R&R simulator software....Rapid and Reliable fails....uffffffffff Solution: 1. on the CMM Setting (Extras--Setting--CMM) 2. on the Probe TAB erase the Probe Type by NOTHING 3. then when ask about to eliminate the old stylus (I check YES) 4. begin again from define the Probe...ex: RDS-CAA and so on. 5. create the new set of stylus... Link to comment https://qualityforum.zeiss.com/topic/15712-masterprobe-planner-offset-rds-xxt/#findComment-85582 Share on other sites More sharing options...
