[Ia...] Posted May 21, 2020 Share Posted May 21, 2020 Hi , When I try to select multiple planes and copy the Measurement strategy from the first plane to all of the others, the location of the probe path (circle path, polyline...) changes on all of the other planes. I have tried Alignment / Keep position on , or off. It only seems to work sporadically. Is there something in the procedure that I am missing? The instructions in the Calypso help file are not very informative....for anything. Link to comment https://qualityforum.zeiss.com/topic/15718-paint-brush-tool/ Share on other sites More sharing options...
[Ri...] Posted May 21, 2020 Share Posted May 21, 2020 I've seen this. I believe it has to do with (most likely) that the planes all have different FCS locations, so it is copying/pasting according to the original. For circle paths that are on center, you can go in and correct those. For polylines, that becomes difficult. Link to comment https://qualityforum.zeiss.com/topic/15718-paint-brush-tool/#findComment-85602 Share on other sites More sharing options...
