[Ja...] Posted May 12, 2020 Share Posted May 12, 2020 I need help creating a base alignment using Cylinder1, Cone1 and Cone2 for my Spatial Rotation, and Cone1 and Cone2 for my Planar Rotation. I assume I need to create a plane with Cylinder1, Cone1 and Cone2, and some sort of 2d line with Cone1 and Cone2, but I can't figure out how to do either one. Any help would be appreciated. JasonCapture.JPG Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/ Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Share Posted May 12, 2020 Are you wanting to create a axis between Cone 1 and Cone 2? Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/#findComment-86520 Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Share Posted May 12, 2020 Like thisCapture1.JPGCapture.JPG Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/#findComment-86522 Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Share Posted May 12, 2020 Looks like thisCapture.JPG Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/#findComment-86524 Share on other sites More sharing options...
[Ja...] Posted May 12, 2020 Author Share Posted May 12, 2020 That works for my Planar Rotation. Thank you! Now, can I use a combination of Cylinder1, Cone1 and Cone2 for my Spatial Rotation? Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/#findComment-86526 Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Share Posted May 12, 2020 What feature is Primary? Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/#findComment-86528 Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Share Posted May 12, 2020 What is the Datum setup Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/#findComment-86530 Share on other sites More sharing options...
[SH...] Posted May 12, 2020 Share Posted May 12, 2020 Please sign in to view this quote. Why you are creating a plane using constructed 3D line and the cylinder axis?? Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/#findComment-86532 Share on other sites More sharing options...
[Cl...] Posted May 12, 2020 Share Posted May 12, 2020 I haven't seen the print, but I would think that Cylinder1 would be a tertiary datum? Looks like the part/fixture has a base-plate. That, I would use for spatial. (just based on what I'm seeing) Base as Spatial and Z origin, 3d line as Planar and Y origin, Cylinder1 as X origin? Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/#findComment-86534 Share on other sites More sharing options...
[Da...] Posted May 12, 2020 Share Posted May 12, 2020 Why you are creating a plane using constructed 3D line and the cylinder axis?? I agree there This is how you would do it if you need to You will need to create intersection on each of the Cone 1 Cylinder and Cone 2 Then Recall those points in to a plane The Planes can be Theoretical or Real it is up to you.Capture1.JPGCapture.JPG Link to comment https://qualityforum.zeiss.com/topic/15812-base-alignment/#findComment-86536 Share on other sites More sharing options...
