Runout - Circle to Plane
For this simplified example - Runout of the Bore to Datum B (plane)
My first thought is: DRF is incomplete. It needs a diametric "center point", to rotate around.
My second thought is: If I measure the entire Bore, then I could report Perpendicularity of the Bore to datum B.
Any other thoughts/ideas?
The way that it is drawn is incorrect. It isn't Radial Runout because the Datum is Perpendicular not Coaxial, and it isn't Axial Runout because the feature isn't a Plane it is a Cylinder.
It could be Axial Runout if you flipped the Datum and feature. Either they meant two things, Perpendicularity, or Radial Runout and they forgot the Coaxial Datum.
With runout you are just checking roundness(form).
The better call is total runout. with Total runout you are checking perpendicularity and roundness(form) at the same time.
Why you would need to I have no idea.
Runout is one of those callouts that really shouldn't be used.
It was easy to check with centers to center and Air Rotatory tables. In almost every case controlling Form and Location at the same time makes no sense. They should have separate requirements.
It is the form in-conjunction with the location. You can have perfect roundness, but if the position of the two centers is off, the runout will be out-of-spec.
It depends on the field and application. In the gear world, runout is one of the most important characteristics of the inspection.
"Runout is one of those callouts that really shouldn't be used."
Runout is one of the prime tool used by design engineers ,while balancing a rotating mass.
Aren't you including location, too? For example, if the form and orientation are perfect, any deviation would be location, right?
This can be said, without saying this:
I saw this hours ago and I would add that most of us who has been in the forum for the past 10 years can agree that this is simply a troll looking to get a rise out of the forum, right?
I've worked with Mechanical Engineers my entire life, 98% of them had/have ZERO GD&T training. That number could be 100% if we count the kids coming out of school today.
GD&T is the integral part of mechanical engineering, as far as mechanical engineers are concerned they do not require any special training ,they will learn it accidentally.......
Engineers are experts in GD&T .. boy how I wish that were true.
In my experience the majority of issues that are caused in manufacturing is due to that statement not being true.
I can't believe how many times an engineer has told me when speaking of profile of 0.010 to A B C that "Oh thats the same as plus or minus 0.010" - Not even plus or minus 0.005 but plus or minus 0.010 mind you (thats not even considering the relationship to datums being completely disregarded by the engineer).
In my opinion most engineers are far more focused on the function of the part and see issues with definitions on drawings as being the last thing they are concerned about. Due to that drawings end up being created with incorrect call outs, and then when you speak to the engineer they just say "Well of course that is not what I meant".
There is a big difference between an engineer understanding the considerations necessary to make a functional product and a correctly drawn print.
Oh and as to the original question, I think it should have been true position and then had the roundness callout. True position would control the axis of the part perpendicular to the face which seem like the actual intent of the call out shown.
Why I say that is that Form is independent of location. Only in Gears and Splines is Form tide to location. In bearing the roundness of the bearing press fit has nothing to do with allowed misalignment. Making runout the wrong callout.
