[Is...] Posted May 12, 2020 Share Posted May 12, 2020 I have a Loop where I’m suing the command measure(“”) to recalculate the feature values .. works OK.. However when I recalculate multiple ZMP files with the tool: “Subsequent evaluation of several measurements” the command: measure(“”) doesn’t work.. Is there other command that I can use to replace: measure(“”) ?? ValLoopZ =0 // this variable applies changes in the features measure("PlaneatT") measure("IntA1x") measure("IntA2x") measure("IntA3x") measure("IntA4x") measure("CTracks") ValLForm=getActual("CTracks").form ValLstp=0.2 repeat ValLoopZ = ValLoopZ+ValLstp measure("PlaneatT") measure("IntA1x") measure("IntA2x") measure("IntA3x") measure("IntA4x") measure("CTracks") if ValLForm > getActual("CTracks").form then ValLForm=getActual("CTracks").form else ValLoopZ =ValLoopZ -ValLstp // prev. value ValLstp=-ValLstp/2 endif until abs(ValLstp) <= 0.0001 // in case the previous value was correct: measure("PlaneatT") measure("IntA1x") measure("IntA2x") measure("IntA3x") measure("IntA4x") measure("CTracks") Link to comment https://qualityforum.zeiss.com/topic/15822-other-function-instead-of-measurequotquot/ Share on other sites More sharing options...
