PiWeb Protocol and PCM List
This is great if there is such an opportunity. The fact is that we recently started using PiWeb, and just started to study it. Could you please explain by example how to do this?
I mean how to access the PCM List, because no matter how much I search, I can’t get this variable out.
PCM List in the attachment.
PCM-Liste_Kamaz_Block_OP10-OP150_6_Cyl.txtFetching info...
Hello Denis,
check the attached inspection, try to intergrate the modifications
Modification are labled with "HKe:"
Modified template at inspection folder ..\PiWebReportingTemplates
Klaus
1828_3a68d8ee92f331027508bd009f728e28.zip
