PCM naming
filePath = "T:\DMR\CMM Data\101228 Op-10_Rev_A\"+ getRecordHead("planid")+ getRecordHead("partnbinc")+".txt"
if fileExists(filePath) then // if it can't find the file then it will not error out.
if response == "Set-up"
copyFile(filePath,"T:\DMR\CMM Data\Setup\theresults.txt")
else
copyFile(filePath,"T:\DMR\CMM Data\Production\theresults.txt")
endif //inquireList
else
message("could not find file : " + filePath)
endif //fileExists
In the code above, why can't I re-name the text files from theresults.txt to 123456.txt?
I tried it, and Calypso won't allow it.
https://qualityforum.zeiss.com/topic/15896-pcm-naming/
