Curve...who has a grasp of this?
We have parts that get a developed bore shape in the center of a cylinder. We use curve to inspect it. Engineers give me the points that go 360 around this "developed bore" The guy here before me would bring these points in as "text deliminted" file. It comes from an excel spreadsheet. Every point is shown with X,Y. Its kinda hard to explain because I don't really know much about it. Has anyone done something like this before? Someone with a good knowledge of curve might be able to assist.
Lincoln
https://qualityforum.zeiss.com/topic/15912-curvewho-has-a-grasp-of-this/
If you are bringing in an txt file with the nominals you will need the X,Y,Z, and vector data.
Create a blank Curve - open it up - drop down where it says Nominal point - select Nominal Geometry Manipulations - Read nominal values - Select ASCII Files - hit the folder icon, and select the txt file.
