Distance between two circles
I'm using Caliper distance to get the distance between two circles, which defaults to the outside distance. Is there an option to switch this to the center point distance, or the inside distance?
Inside of the characteristic, for each features that you are evaluating it will default to the maximum distance, but you can drop that down and change each one to either the maximum, center, or minimum.
