Obtaining Channel Width from Radial Positions
Hi gang,
I need to calculate channel widths at different radial areas. There is a cylinder I can measure in the middle that can act as a secondary part alignment. I figure I need to make theoretical lines or planes at different deg positions and take the radial difference of the intersection of the channel walls and the theo line/plane. I can work with a CAD model so it should be easier. See the below image for a rough sketch. The only thing is I don't know how to do that in Calypso. Can anyone direct me to a guide or spell it out for me how to execute this in Calypso? This seems like it should be very intuitive but I can't figure it out. 😕
Thanks in advance.
I would use space points at the locations desired and use a simple point distance....Easiest way would be to
1) Create a single set of space points with no rotation
2) Create alignments at the angles you would like to check the distance
3) Copy the original 2 space points and change their alignment to the new rotated alignments while the "Keep position" box is checked 2582_cf48fd168eab39d97e4c2dcc3312f0bb.jpg
After all your points are probed you can do simple distance calculations for each set.
