Recalling points into curve
I am trying to make 1 curve from multiple curves but when I recall the feature points, the new curve appears to have an offset close the probe radius. Same thing happens when recalling 1 curve into a new curve.
Part 2. The curves are not adjacent to each other so there is a line that connects the curves. Assuming I can resolve the offset problem above, is it possible connect the curves without the space in between the curves affecting the result?
https://qualityforum.zeiss.com/topic/16378-recalling-points-into-curve/
