Bonus from a slot with lines
Is there another way to get bonus from a slot without using sym plane or PCM? I dont think there is but i am sure open to some new learning if so 😃
The engineers that do all the drawing where i work will use very small features of size sometimes as datums. Those types of features are way to small for a plane but just right for a polyline or a space point. I cant use the MMC or MMB unless its a plane.
I appreciate you guys help very much....
Thank You 😃
Jason i just read through the document and i must say thats some good good right there... i will apply it in a little while when i get back to it.....That perpendicular tool is a great tool that i have just recently started using.
Thanks again
you can define a symmetry plane, calypso will automatically calculate the slot distance by creating a new feature, after adding mmc.
