[Je...] Posted February 28, 2020 Share Posted February 28, 2020 So im having an issue with my probe not hitting in the same spot everytime. It is effecting my measurements and im not sure what is going on. Can someone help. And for some reason I feel like everything is backwards on my screen vs on my actual CMM. When I take hits on one side its putting them on the other, like my model isn't right but I cant get it to transform correctly. Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/ Share on other sites More sharing options...
[Am...] Posted February 28, 2020 Share Posted February 28, 2020 Can you upload some pictures? Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91246 Share on other sites More sharing options...
[Je...] Posted February 28, 2020 Author Share Posted February 28, 2020 Please sign in to view this quote. So those hits I actually took on the CMM and they should be on the side but don’t show up on my car model that way.D1CE8C41-4B43-4FA0-8F2F-1FA22E4E9EAE.jpeg Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91248 Share on other sites More sharing options...
[Ky...] Posted February 28, 2020 Share Posted February 28, 2020 Can you try to hit your points in the CAD model. That way you are sure the probe is going to where you want before you run it. I have found if you have a CAD model it seems to work better that way. IMOP. Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91250 Share on other sites More sharing options...
[Ke...] Posted February 28, 2020 Share Posted February 28, 2020 Are you looping your Base Alignment? Are you using a Planer Rotation in your Base Alignment? Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91252 Share on other sites More sharing options...
[Ro...] Posted February 28, 2020 Share Posted February 28, 2020 Make sure you have rotation set in your alignment, then loop it 2 times. Looping will help fix any issues you might have with fixturing & repeatable load.jkjhhghfgfg.JPG Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91254 Share on other sites More sharing options...
[Je...] Posted February 28, 2020 Author Share Posted February 28, 2020 I am using a planar rotation. I have a 3d line because I measure plane circle circle. Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91256 Share on other sites More sharing options...
[Je...] Posted February 28, 2020 Author Share Posted February 28, 2020 Please sign in to view this quote. I do use a planar rotation. I have a 3d line because I use plane, circle, circle for my alignment. Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91258 Share on other sites More sharing options...
[Ke...] Posted February 28, 2020 Share Posted February 28, 2020 Please sign in to view this quote. There could be an issue with your Planar Rotation... screenshots? Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91260 Share on other sites More sharing options...
[Je...] Posted February 28, 2020 Author Share Posted February 28, 2020 Please sign in to view this quote. Could it have something to do with the planar rotation being in the XPLUS axis? Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91262 Share on other sites More sharing options...
[Me...] Posted February 28, 2020 Share Posted February 28, 2020 Based on your previous posts it seems you're using features for planar rotation that do not accurately define a proper vector to solve an alignment. Does your feature that defines the planer rotation have vectors that are perpendicular to your spatial feature? Post a picture of your Base Alignment dialogue box and a picture of the features that make up the Base Alignment on the model. Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91264 Share on other sites More sharing options...
[Am...] Posted February 29, 2020 Share Posted February 29, 2020 I think we need to see what the base alignment looks like, I think its gonna have something to do with you planar rotation feature. Link to comment https://qualityforum.zeiss.com/topic/16408-not-hitting-in-the-same-spot-everytime/#findComment-91266 Share on other sites More sharing options...
