How to translate features/characteristics in Calypso?
Hello I am pretty new to calypso and have had to learn without any training. So forgive me if this is a stupid question.
I have a plate with 25 pockets all equidistant from each other and with about 15ish features each. Is there a way to translate one pocket's features/characteristics? I do not want to have to go through one by one and do each pocket individually. Thanks in advance!
This can be done as follows. Open feature you would like copied, and in the pull down select pattern. A selection window opens and here you can select how you need to pattern the copied feature. 333_62cc0f966a22b7825bb2d1ec1cec3c1b.jpg
This can be done with each feature individually or you can can group a family of features highlight the group, right click and select pattern for the group. 333_1209824afdedeeb06408a9ece03463f5.jpg
Be wary of you clearance planes and articulations of the stylus system.
Greg
Function
Select here the algorithm for the definition of the pattern features:
First formula then pattern: The first pattern feature is defined via the formulas. The other pattern features are defined in the same way according to the grouping parameters. Default setting if get Actual or LOOP is not used in the feature.
First pattern then formula: The first pattern feature is defined via the formulas. For the other pattern features, the formula is indexed accordingly and reused. Default setting if get Actual or LOOP is used in the feature.
This selection has no effect if the feature does not contain any formulas.
This info came from the online help
