[Da...] Posted July 3, 2019 Share Posted July 3, 2019 I have following issue: Measurement plan 1 has corner rounding activated (set to 10), Measurement plan 2 it is set to 0. If we run plan 2 first, everything is fine. But if we run plan 1 first and then 2 after, in plan 2 it will also round the corners. In plan 2 there are some really tight travel path, so we don't want to use corner rounding there. Any ideas how to stop it for plan 2 (setting is 0 already)? Link to comment https://qualityforum.zeiss.com/topic/16746-vast-navigator-corner-rounding/ Share on other sites More sharing options...
[Ri...] Posted July 3, 2019 Share Posted July 3, 2019 You could modify your default strategy to use 0.0 "edge deviation" on paths. Then when/if you want to use an actual radii for scan path vertices you can just change the edge deviation value in that feature/s strategy page directly/individually. Link to comment https://qualityforum.zeiss.com/topic/16746-vast-navigator-corner-rounding/#findComment-93634 Share on other sites More sharing options...
[Jo...] Posted January 22, 2020 Share Posted January 22, 2020 Dear Daniel, I also have this issue, corner rounding is activated after I run "cross slide", I tried a lot and I found set to " 0 " or " **Defalut " was unavailable, but if you set to "0.5" in the dropdown list and run your plan, the movement gonna be OK without rounding moving by naked eyes 🤣 So I set to 0.5, run my plan,and then set to 0. Link to comment https://qualityforum.zeiss.com/topic/16746-vast-navigator-corner-rounding/#findComment-93636 Share on other sites More sharing options...
