Incrimental Part Number - Excel
We activate the Zeiss Characteristic.xlsx report in several of our programs.
One of these programs .xlsx report doesn't match the custom printout numbers
entered in the Incremental Part Number.
Well... that sounds weird. Doesn't match, in what way?
Did someone change the cells in the upper portion? Does the cell location match?
I'm not too familiar with the macros; is it possible to copy and paste the cell from another sheet?
I'm getting this complaint from another facility via e-mail and screen shots, so this is what I know so far. We use the Custom Printout and the Characteristic .xlxs. From Start Measurement - Report Header Data, the operator enters the Incremental Part
Number. He says that the incremental Part Number doesn't match what's on the Excel report?
If the problem you are having with the incremental part number is just as it relates with Excel you need to do the following.
1st: You need to go to resources>Define Printout>Default printout/Warning Limit and at bottom of window you will see Excel Report.
It is here you insert the path to the template being used (see picture) 333_388325930118477bd6cf67636fe30dc3.jpg
These templates are located C:\Users\Public\Documents\Zeiss\CALYPSO\data\excel_report
2nd: The ReportINI.xls file should be embedded in Excel 'C:\Program Files\Microsoft Office 15\root\office15\xlstart\ ReportINI.xls'
Now when the program is run, the Excel-printout is no longer grayed out and can be activated.
After run is completed 4 files are created. Characteristic.txt, Feature.txt, Header.txt feed the ReportINI.xls file which creates the final Excel Results file.
This is a sample of one of ours 333_57cc5fb564744268822ff9c649693ec9.xls
Already doing that Greg. The problem is, the incremental part number on
the custom printout does not match what's appearing on the .xlxs report.
Clarke,
Is it possible that there is some PCM coding in your postsettings that set Incremental Part Number to a variable?
It would look like something this:
SN=getRecordHead("A User Defined field like Serial Number")
setRecordHead("partnbinc",SN)
Regards,
Keith
Oops, should have been more attentive when I first read your post.
What version of Calypso are you running? I remember reading or hearing from someone Calypso 2019 will no longer support Custom Printouts. They are really pushing for PiWeb to be the sole reporting entity.
