[Ca...] Posted August 8, 2018 Share Posted August 8, 2018 Lets pretend I have a callout, it's a 1.500±.005, with a .005 parallelism at MMC. How do I add MMC to parallelism? I have half a memory about creating a bogus diameter from the actual 1.500±.005 length, and it gets fuzzy from there.... Thoughts? Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/ Share on other sites More sharing options...
[To...] Posted August 8, 2018 Share Posted August 8, 2018 Is this 2 parallel bores or planes or what? Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94312 Share on other sites More sharing options...
[Ca...] Posted August 8, 2018 Author Share Posted August 8, 2018 It's plane to plane. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94314 Share on other sites More sharing options...
[Ri...] Posted August 8, 2018 Share Posted August 8, 2018 1.500±.005, with a .005 parallelism at MMC. If the 1.500 dimension is the width of a gap between the considered feature and the datum feature then 1.495 would be the MMC. Right click on the Tolerance field in Parallelism and click on Formula. The formula will be the actual width value, either from a distance or from location, minus 1.495, then that value plus 0.005 It might be a good idea to describe your method of determining MMC bonus in the comment field. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94316 Share on other sites More sharing options...
[Ca...] Posted August 8, 2018 Author Share Posted August 8, 2018 That's perfect Richard, thank you! Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94318 Share on other sites More sharing options...
[An...] Posted August 8, 2018 Share Posted August 8, 2018 Please sign in to view this quote. The distinction between feature an datum yields some difficulties in understanding. See attached.Parallelism_and_MMC_1.pdf Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94320 Share on other sites More sharing options...
[To...] Posted August 8, 2018 Share Posted August 8, 2018 What's the matter Andreas? Couldn't sleep? 🤣 🤣 🤣 Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94322 Share on other sites More sharing options...
[Aa...] Posted August 8, 2018 Share Posted August 8, 2018 Not to be a pedant here, but a plane isn't a feature of size. Ergo, material condition modifiers can't be applied to tolerances applied to planes. If the two planes are nominally parallel, then together they form a width, which is a feature of size, and the 1.500 +/- .005 is the size tolerance on the width. Rule #1, the Envelope Principle, says that at MMC, perfect form is required on features of size. There ways to override this rule and relax form control. 5.4.2.1 of Y14.5 describes the appropriate method for the situation at hand. Treat the 1.500 +/-.005 as a width. Apply a flatness tolerance of .005. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94324 Share on other sites More sharing options...
[Jo...] Posted August 8, 2018 Share Posted August 8, 2018 Is the parallelism applied to a single plane, relative to a datum plane or is it applied to a width relative to a datum plane that is NOT one of the walls of the width? If it's the former then it's a bad callout. As someone previously said, you can't modify a surface at MMC. If it's the latter then maybe what Richard said will work considering Calypso doesn't even give the option for parallelism at MMC. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94326 Share on other sites More sharing options...
[Ri...] Posted August 8, 2018 Share Posted August 8, 2018 No it doesn't and Parallelism of two Planes in Calypso would be calculated as a single Plane relative to a Datum Plane, which makes MMC troublesome. My thinking for this was as the distance of the two planes deviates from the minimum allowed distance, the amount for the Parallelism of the considered Plane could increase. Another, perhaps more appropriate solution could be to ignore the MMC but then inspection risks rejecting good parts. My solution utilizes MMC with a rational (maybe) reason. That's why I suggested making a note in the comment field describing the method for calculating bonus. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94328 Share on other sites More sharing options...
[An...] Posted August 9, 2018 Share Posted August 9, 2018 Please sign in to view this quote. See attached.Parallelism_and_MMC_2.pdf Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94330 Share on other sites More sharing options...
[Al...] Posted August 9, 2018 Share Posted August 9, 2018 I'm confused, since when can a modifier be used in dimensioning the orientation of features? Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94332 Share on other sites More sharing options...
[Ca...] Posted August 9, 2018 Author Share Posted August 9, 2018 The features are planes. Think of it as both ends of a bolt. See attached.Untitled.png Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94334 Share on other sites More sharing options...
[Aa...] Posted August 9, 2018 Share Posted August 9, 2018 Please sign in to view this quote. 6.4.4 and 6.4.5 specifically address modifiers on orientation tolerances. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94336 Share on other sites More sharing options...
[An...] Posted August 10, 2018 Share Posted August 10, 2018 Please sign in to view this quote. See attached.Parallelism_and_MMC_1.pdf Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94338 Share on other sites More sharing options...
[Al...] Posted August 10, 2018 Share Posted August 10, 2018 I'm glad I'm retiring next year! Can't keep up with this stuff like I used too. 🤣 Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94340 Share on other sites More sharing options...
[Ja...] Posted August 15, 2018 Share Posted August 15, 2018 Aaron, I don't have a copy of those standards. Can you post them here (if it's legal)? As far as I know you can't add a modifier to parallelism. If you do, it becomes profile. I'm sure that's why Calypso doesn't have that capability. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94342 Share on other sites More sharing options...
[Jo...] Posted August 15, 2018 Share Posted August 15, 2018 Please sign in to view this quote. You can modify an orientation tolerance with MMC as long as the feature being controlled is a feature of size and the tolerance is associated with the size dimension. The tolerance then applies to the axis or centerplane of the feature. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94344 Share on other sites More sharing options...
[Aa...] Posted August 15, 2018 Share Posted August 15, 2018 I'm not sure how much of the standard I could legally post. What John said applies to straightness and flatness, too, in Y14.5. ISO 2692 also has examples in Appendix A of applying MMR to orientation tolerances. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94346 Share on other sites More sharing options...
[Me...] Posted August 17, 2018 Share Posted August 17, 2018 The parallelism characteristic will allow a non-cylindrical feature of size to be modified if it’s created with the “Symmetry Plane” feature. Since the tolerance applies to the center plane of the feature, form error will need to be excluded. This can be accomplished by creating a copy of the symmetry plane via “Recall One Feature”, and using it to evaluate the orientation of the center plane with applicable modifier. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94348 Share on other sites More sharing options...
[Da...] Posted January 10, 2020 Share Posted January 10, 2020 Please sign in to view this quote. Thanks for revealing this "hidden" way to go. I think I saw a similar example on https://www.youtube.com/user/CarlZeissIMTCorp/videos or https://www.youtube.com/channel/UCejVy3 ... shelf_id=4, not sure which video. edit: maybe it was one of the LOT (live online training) Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94350 Share on other sites More sharing options...
[Wi...] Posted January 10, 2020 Share Posted January 10, 2020 Engineers usually know less about gdt than CMM guys.....just saying I do not think that its really allowed.... Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94352 Share on other sites More sharing options...
[Mi...] Posted January 11, 2020 Share Posted January 11, 2020 As I was reading this thread and saw the actual call out I was thinking that the callout wasn't to a single plane but to the distance between the 2 planes and that a plane symmetry would be the solution. Didn't even think of recalling it into another symmetry to account for form error. This gives me something to research, I've had several difficulties with similar problems were this may be a solution in those cases as well! Thank you. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94354 Share on other sites More sharing options...
[Da...] Posted January 11, 2020 Share Posted January 11, 2020 Please sign in to view this quote. I knew it's worth it, to revive 1/2 year old thread 🙂 No rush Michael, but when you discover something, please report back! Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94356 Share on other sites More sharing options...
[Mi...] Posted January 11, 2020 Share Posted January 11, 2020 I just did. I had a profile on a plane that was called out to a single datum plane. It was giving me trouble by introducing form error from the datum which was in turn created by recalling 4 separate planes. I created a new plane and recalled the datum plane into it and used that plane as the datum. Didn't change it much but it helped. Link to comment https://qualityforum.zeiss.com/topic/16860-parallelism-with-mmc/#findComment-94358 Share on other sites More sharing options...
