[Me...] Posted March 30, 2019 Share Posted March 30, 2019 you could help me look at this example a long time ago but I am having sintasys errors I am trying to have the result saved in an excel format using PCM but I do not have much knowledge if you can guide me, this is what I am doing:image.jpg Link to comment Share on other sites More sharing options...
[Ro...] Posted March 30, 2019 Share Posted March 30, 2019 Possibly try changing your extension to ".CSV". CSV is an excel format and will change itself into an XLS or XLXS when it is generated. Your filePath should end in an \ if you're adding to it as a part of a longer address. Also i see you have your extension included in your filePath line, but then in your dirPath you add N1 + Lot +PN + another extension after the filePath Also, does getRecordHead for part number start with a capital P or lower case p? so your final result will be C:\Doc n Set\admin\desktop\test.xlsN1inputLotinput_partNumberinc.xlsfilepath1.JPG Link to comment Share on other sites More sharing options...
[Me...] Posted March 31, 2019 Author Share Posted March 31, 2019 You can already get it to be finalized but I need the results of each of the evolutions of the dimensions to be saved in the same Excel file. Example: Piece # 1, Piece # 2 ... ..Ect. Presettings LN = getRecordHead("order") Postsettings rotateReference() //Dims to Excel filePath = "C:\Documents and Settings\Administrator\Desktop\Tang Flat Profile_.0934\feature 200.xlx\" ext = ".csv" //N1 = getRecordHead ("Grind Tang_Rev. B 9.22.16_543_.0934") //dirPath = filePath + N1 + (" ") +date()+" "+time()+ ext Lot = getRecordHead("order") partnum=getRecordHead("partnbinc") dirPath=filePath+Lot+ (" ") +date()+" "+time()+ ext display(dirPath) if fileExists(dirPath) == true deleteFile(dirPath) endif //#1 DIM200_1 = getActual("200 - Profile_1").actual addToFile(dirPath,date()) addToFile(dirPath,time()) addToFile(dirPath,("Lot Number : "),LN) addToFile(dirPath,("200 - Profile_1 : "),DIM200_1)PCM.rtf Link to comment Share on other sites More sharing options...
[Ro...] Posted April 1, 2019 Share Posted April 1, 2019 I don't have any programs where i "append" a program, adding to it. All my programs i create i "overwright" or since i'm sending to a folder to be digested by Winspc, the file that i save to is emptied every 10 seconds or so there's very few instances where the same part file is saved to a folder, but if it does happen then the file is overwritten. Winspc will grab the file and process it, then move the file into another archive folder. We "Bag & Tag" every part we make so im safe creating a new file that consists of "Partnumber_workorder_individualPartNumber.txt". Link to comment Share on other sites More sharing options...
[Ro...] Posted April 1, 2019 Share Posted April 1, 2019 But if you're still having problems, id think that the ".XLX" in the middle of the file name could be an issue. (is XLX a valid extension?)filepath2.JPG Link to comment Share on other sites More sharing options...
[Er...] Posted April 2, 2019 Share Posted April 2, 2019 The ".xlx" will not cause any issues. And as you see it's not an extension of a file, it's part of the path name "....\feature_200.xlx\file.csv" You can simply append to the csv-file if you need more then one part in the same file. How ever, that can become messy quite quick. Since csv don't support tabs. That can be fixed by a script that place every measurement in a tab of it's own and creates a "real" excel file. If that's the target. Link to comment Share on other sites More sharing options...
[Me...] Posted April 2, 2019 Author Share Posted April 2, 2019 the idea is to be able to save the results in an excel format that handles SPC graphics as we do not have an SPC software so we are trying to use these Excel formats Link to comment Share on other sites More sharing options...
[Cl...] Posted January 6, 2020 Share Posted January 6, 2020 Please sign in to view this quote. Can I ask were did you get these pre/post PCM settings from? Link to comment Share on other sites More sharing options...
[ge...] Posted January 7, 2020 Share Posted January 7, 2020 This PCM was previously posted on the group. Link to comment Share on other sites More sharing options...
[Cl...] Posted January 7, 2020 Share Posted January 7, 2020 I thought it looked familiar, I posted it. Thanks. Link to comment Share on other sites More sharing options...
[ge...] Posted January 7, 2020 Share Posted January 7, 2020 It was very useful I had some problems to understand but it worked Link to comment Share on other sites More sharing options...
[Cl...] Posted January 7, 2020 Share Posted January 7, 2020 I've actually got a new and improved version of that same PCM, if you are interested? Link to comment Share on other sites More sharing options...
[ge...] Posted January 7, 2020 Share Posted January 7, 2020 If I am interested if you can share it I would appreciate it Link to comment Share on other sites More sharing options...
[Cl...] Posted January 8, 2020 Share Posted January 8, 2020 For a part family: This will prompt the operator to choose which size part they want to run. It will also save dimensions 200a & 200b to a separate folder. Link to comment Share on other sites More sharing options...
[ge...] Posted January 8, 2020 Share Posted January 8, 2020 thank you very much it will be very useful to separate CHR by cavities Link to comment Share on other sites More sharing options...
