Para files
What is the correct location to save PCM .para files? Must they be
a .para? I see in one program we have that was written by Zeiss has
a parameter file that is .txt?
Correct location is really wherever you deem to be a protected, accessible location for the program. As long as the program can pull from that location (no read/write restrictions preventing this), and as long as no one can access them to modify them, then the location can be anywhere.
As far as type, either .para or .txt will work. Calypso can read both as a parameter file. The pro of using .txt files is that Calypso automatically looks for .txt files when you try to "open" a PCM file in the parameter windows. I am not aware of any cons against either.
1, Instead of runPCMFile try using readPCMFile.
2, if you've got a short list of changing parameters, try using an If statement instead of a parafile to set your variables.
Itll look something like this, you should be able to edit it from here to suit your needs.
clearCAD()
itemSelected = inquireList("Is this part","Ø_.1247","Ø_.0934")
if itemSelected=="Ø_.1247" then
loadCad(getActualInspectionDir()+"\"+"Ø_.1247.cad")
TAB= 0.009
endif
if itemSelected=="Ø_.0934" then
loadCad(getActualInspectionDir()+"\"+"Ø_.0934.cad")
TAB= 0.010
endif
I just realized another issue. Because I have two sizes, I had two programs, so In my Post settings I have one line of code that sends data from whichever program is being run. Now that I'm using one program for both, how do I get Calypso (PCM) to sent
the data do two different locations based on the chosen part number (size)?
Easy, in your parafile (or If Statement) set a variable with your partnumber in it
PN="Ø_.1247"
then in your output, youll have a line like
filePath = "X:\CMM\REPORTS\CUSTOMER\PART_FAMILY\"+PN+"\"
Additionally you can now use a text element named "Part Number" and put it at the top of your report and you can have the current part number show on your report.
You may need to use formatL(PN) because your part number will probably be a numeric value and text boxes dont like that. (its a quirk)
  • 2 weeks later...
The Presetting's (I've got this part ironed out), its the post settings and were I want the data to go based on the part size I choose in the presetting's that's giving me trouble.
LN = getRecordHead("order")
clearCAD()
dir = getActualInspectionDir()
Part_Size = inquireList("Which size part would you like to run?", "Diameter_.1247", "Diameter_.0934")
selectCase Part_Size
case "Diameter_.1247"
readPCMFile(dir + "\Tang_.1247.PARA")
loadCADFile(dir+"\.1247.sab")
case "Diameter_.0934"
readPCMFile(dir + "\Tang_.0934.PARA")
loadCADFile(dir+"\.0934.sab")
endSelect
My Postsettings
rotateReference()
//Dims to Excel
filePath = "T:\DMR\CMM Data\Medtronic\Diameter_.0934 (feature 200)\"
ext = ".csv"
//N1 = getRecordHead ("M964812AXXX_Rev. C")
//dirPath = filePath + N1 + (" ") +date()+" "+time()+ ext
Lot = getRecordHead("order")
partnum=getRecordHead("partnbinc")
dirPath=filePath+Lot+("_")+partnum+ext
display(dirPath)
if fileExists(dirPath) == true
deleteFile(dirPath)
endif
//#1
DIM200_1 = getActual("200a").actual
//#2
DIM200_2 = getActual("200b").actual
addToFile(dirPath,date())
addToFile(dirPath,time())
addToFile(dirPath,("T:\DMR\CMM Data\Medtronic\Tang Flat Profile_.0934 (feature 200)"))
addToFile(dirPath,("Lot Number : "),LN)
addToFile(dirPath,("200a : "),DIM200_1)
addToFile(dirPath,("200b : "),DIM200_2)
Robert, thank you for the help with this, but I must be missing some small detail?
Well for starters you have your N1 and dirpath lines turned off by the "//", so calypso isnt even looking at them (they are probably greyed out).
Secondly, im not sure what you're doing with your N1 line, i use
N1 = getRecordHead ("planid")
N2 = getRecordHead ("lotid")
to get part number (planid) and a user input (lotid) for my file saving, but your line N1 = getRecordHead ("M964812AXXX_Rev. C") may be causing issues because M964812AXXX_Rev. C is probably not a retrievable field in your VPHEAD.GRA header.
The Post settings are from an existing program that Zeiss wrote for us.
I have not altered the "N1" line at all, so I'm not sure why it would be turned off (//)?
All I really did was make some minor changes to the presetting's so the program and
model would change. Based on what you stated here, I'll try and figure it out, thanks again.
Guys,
The N1 lines are greyed out, and not being used. These are not causing any issues from what I can see. The coding redefined "dirPath" again.
If you want them to dump into separate locations, you need to do as Roberto suggested earlier, make each part number a variable.
It would look something like this:
clearCAD()
FP="Diameter_.1247 (feature 200)"
FP="Diameter_.0934 (feature 200)"
endSelect
My Postsettings
rotateReference()
//Dims to Excel
filePath = "T:\DMR\CMM Data\Medtronic\"+FP+"\"
ext = ".csv"
display(dirPath)
deleteFile(dirPath)
endif
//#1
//#2
The text in red is the changes I made that should allow what you are asking. It is untested though.
Keith
Thank you Keith. I did try what Roberto suggested, but it didn't work. I must have missed
some small detail. I made the changes/additions that you suggested, and it works now.
The Text element worked well Roberto, thanks.
Many thanks!
I appreciate all the help. I've got it doing what it needs to do with one exception.
When the program is near the end and ready to spit out the report, I get the
following error(s). Any idea what's causing this?
getActual("200a").actual will work well for something like profile deviation, but if you're trying to get a size or location/distance you may need to use getActual("200a").diameter, or radius, or x, or y.
They are line profile deviations. I should add that I am not "physically" running the program
I'm executing it from "Plan - Subsequent Evaluation", so there is no actual variable data.
Is that why I'm getting the error?
