True Position Projected
Why are you using a projected tolerance zone for Datum D? You need to measure the actual cylinder over the length noted, not a circle and project it. All that is doing is using the data from the circle and applying it at a different location based on your alignment, which doesn't represent the actual feature condition of Datum D.
If you look at the picture I posted I clearly am not projecting Datum D. Cylinder2 is what is being projected and measured correctly. I know that I should not use a circle for the datum but due to the small length of Datum -D- and the amount of area I have to measure due to my fixture, I am using a Circle instead of a Cylinder for Datum D.
I just need to know how to adjust that projected zone how the print asks, which is .190.
The FCF associated with balloon #8 is not a projected tolerance zone. There needs to be a projected tolerance zone modifier in the FCF in order to invoke this. The chain Line that the datum feature symbol [D] is attached to is stating that the Datum feature only exists in that area.( A datum target area with cross-hatchings would probably have been clearer for a cylindrical datum feature like this. ). So delete that Projected tolerance zone you made and just measure datum feature D as a cylinder at the depth specified.
Ok then your reference length should be .19 and your offset should be 0. The projected tolerance zone starts at the top of the hole, and projects .19 above that. You want to see that yellow arrow reflect this. Any offset you put in will be applied past the "Datum C Plane1" feature.
