[Da...] Posted December 31, 2019 Share Posted December 31, 2019 This may be a PiWeb solution, but is there a method where I can have the output Pdf files from Calypso annotate the filename with some arbitrary character based on whether the run exceeded limits, such that a failed part would be obvious in the results folder? Large CNC machine shop here, many CMM runs per shift, and I'd like to find the failed part results quickly vs. reviewing each output file... Link to comment https://qualityforum.zeiss.com/topic/16944-marking-output-files-for-passfail/ Share on other sites More sharing options...
[Ro...] Posted January 3, 2020 Share Posted January 3, 2020 First of all, i don't use Pi Web so i may be going at this completely wrong...... If you have PCM you can an If statement in your post script to set a variable for in tolerance vs. out of tolerance. in this case i set the variable "Status" to "In tolerance", then if something checks out the variable will change to "out of tolerance". inspection Tolerance State for each run is either "in tolerance" which is 11 characters or "out of tolerance" which is 14 characters. Status ="In Tol" Len=len(inspectionToleranceState()) if Len == 14 then Status ="Out of Tol" endif of course if you don't like that in your file name you can change the Status to be i for in & o for out, or figure out an arbitrary character that you prefer for each Link to comment https://qualityforum.zeiss.com/topic/16944-marking-output-files-for-passfail/#findComment-94830 Share on other sites More sharing options...
[Ke...] Posted January 3, 2020 Share Posted January 3, 2020 Similar to what Roberto stated, here are the lines of code I use to accomplish this: //Get PASS/FAIL tag TolStateStr=inspectionToleranceState() selectCase TolStateStr case "outOfTolerance" TolStateID="FAIL" endSelect selectCase TolStateStr case "inTolerance" TolStateID="PASS" endSelect selectCase TolStateStr case "outOfLimit" TolStateID="PASS" endSelect selectCase TolStateStr case "notDefined" TolStateID="Not Defined" endSelect selectCase TolStateStr case "noResults" TolStateID="Uncalculated Results" endSelect I then add the variable "TolStateID" to the end of my PDF naming convention. Cheers, Keith Link to comment https://qualityforum.zeiss.com/topic/16944-marking-output-files-for-passfail/#findComment-94832 Share on other sites More sharing options...
